Yep. The lift arms on my B7100 lower REAL SLOW, unless I push on them, or an implement is on it. It takes weight to evacuate the oil from the lift cylinder, and the arms alone are pretty light. You may need to adjust the knob under the seat, but if it is just a matter of slow fall, then it is pretty normal.Is there any weight on the hitch? The 3pt is power up and gravity down. You can push it down by hand or have something hooked to it.
