I am seeking recommendations for a 4 way with float loader valve to run a front dozer/snow blade on my B6100.
The blade is homemade so if there is a certain type valve that works better than would have come on my tractor if it were optioned with a loader, then I would like to upgrade up front.
I just picked up the diverter block to tap into the 3 gpm? low flow system.
https://www.surpluscenter.com/Hydraulics/
Any particular valve spec I should be looking for?
I would probably run 2 single ended rams instead of one double ended ram for angle and 1 double ended for lift, float and down pressure.
