help on my b3200
200mph
Mar 3, 2017
1,228
59
PA
Try reconnecting the hydraulic quick disconnects and make certain the collars are at end of travel once connected.
200mph
Mar 3, 2017
1,228
59
PA
Did you try swapping the two lines?
What is the result when you do so?
5,099
How do you know it will dump if it won't roll back?
Did you swap the 2 rollback and dump lines with the 2 lift lines, and when you do does the roll control work for lift and fall, and still nothing on the roll?
If so you have either a bad disconnect on the loader side of the unit, or you have blown a cylinder.
josh25
marietta sc
If u barely move the handle it will roll back real slow up and down fine and dumping is fine .. no leaks what so ever on it
5,099
Sounds like you have a bad or clogged Quick Connect! ;)
