Bill, if the tire is good, tread and all, the bead just slips on the rim, I have used pine tar (like baseball players use on their bats for grip). Break the tire down, brush some pine tar on the bead and air it up. Beats throwing away a good tire!
I thought the one would have been more than enough!I'm working on 2 B7100's right now, one piece at a time is the only way to tackle them!
In a weird series of events... I got my old one back home for good!I thought the one would have been more than enough!
That's because she's super smart!Alright!
Actually, Carolyn guessed that is what happened.
The copper washers only go between head and injector.Quick question, do copper crush washers go between the bottom if the injectors and the head, and another copper crush washer above the overflow adapters? I bought new injectors, and they did not come with copper washers? I have 3 I bought, do I need 3 or 6 copper washers?
Sent from my Pixel 2 XL using Tapatalk
Be certain that the manual shut down knob is fully seated in the run position.Thank you D2, I will give that a shot after work. I was hitting the starter for 5-7 seconds per try last night. Charger is on the battery now, hopefully this evening she is running again.
