While mowing today the mower just shut off and would not restart, (no crank) when i turn the key i get no clicks or anything, the heater light will come on when turning the key to that position but dont hear anything. If a safety switch was bad i should still get solenoid sounds when turning the key shouldnt I? Battery is good, cables are clean and ground cable has a good/clean connection. Checked the 5 fuses in the fuse block they are good and so is the 40amp fuse.
