Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 11-19-2011   #1
Profnohair
3rd Yr. Apprentice
Equipment: L1500, 42" bh, box blade, Mahindra 450 with BH, FEL, etc. G6200HST
Default Broken Off Shift Lever Question
Ok, since you were so helpful with my oil drain plug problem, I am here for more help. The shift lever is broken off on the new tractor. It has had a vise grip pliers being used to change gears which is fine for bush hogging but not for other more demanding task which require frequent direction changes. If I were to remove the 5? bolts that hold the plate on will it just lift out of there without all kind of parts falling out of place? In other words can I just remove it to have it welded and it will go right back in place or are there parts in there that will become misaligned when I remove the plate.
Thanks,
Profnohair.
Profnohair is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-19-2011   #2
fj40dave
2nd Yr. Apprentice
fj40dave's Avatar
Equipment: L295DT
Default Re: Broken Off Shift Lever Question
Couple of options come to mind:
Buy a dye and thread the stub, attach a section of pipe with a double female coupling
I would look at the parts diagram/picture you can have sent to you by Messicks....see what's beneath the cover.....I imagine it's just a drop-in shift assembly, but the parts picture would help.
What model tractor is this?
__________________
Pictures of the L295DT I rebuilt in 2010
http://s1095.photobucket.com/albums/...bota%20L295DT/
fj40dave is offline   Reply With Quote
Old 11-19-2011   #3
Profnohair
3rd Yr. Apprentice
I guess the model would help. It is a L1500.
I could go the die and thread route but there is not enough clearance to turn the shift lever to tighten it on the gas tank side. I would still have to remove the plate to do it. So the question still has to be answered before I take it apart.
Profnohair.
Old 11-19-2011   #4
Kubota Newbie
3rd Yr. Apprentice
Equipment: M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
On my M series you can take the shifter plate off with no problems, just need to get the ball ends of the shifters aligned in the fork slots as you re-assemble. Wasn't a big deal.
Do you have the broken off piece? There was probably a spring/retainer pin arrangement similar to the other shifter. Will want to make sure the weld is smooth so that those pieces can be re-assembled , those arrangements usually slide over the top of the shifter and the spring and top cap give a little friction fit to the shifter assembly.
Kubota Newbie is offline   Reply With Quote
Old 11-19-2011   #5
Profnohair
3rd Yr. Apprentice
Unfortunately I do not have the spring. I can most certainly obtain a spring to replace it and maybe drill a small (brad sized) hole in the lever at the correct level to provide the right amount of 'friction' needed.
Old 11-19-2011   #6
stepdoctor
1st Yr. Apprentice
Equipment: L295DT, loader, backhoe, John Deere 40W, International 140
A welder is a good investment when owning and working on tractors. I have a L295DT and have had to top off of mine and it went back with no problems. Good luck
stepdoctor is offline   Reply With Quote
Reply
Tags
broken off shift lever
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
