Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 04-24-2018   #1
Jiminoregon
New Member
Equipment: B2920
Default Broken steering drag link
broke the bolt on the gearbox end of the steering drag link of my B2920hsd.
Do I need to buy a whole new drag link or is there a way to just replace the bolt?
Jiminoregon is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-24-2018   #2
100 td
Journeyman
Equipment: B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Default Re: Broken steering drag link
If you are talking about the tie rod end that goes into the pitman arm then unless you cut and shut a new one onto the draglink, it appears it's all one part.
The draglink on my B21 is also one piece, one end is flogged, I'll cut and shut something onto it eventually I expect.
100 td is offline   Reply With Quote
Old 04-24-2018   #3
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
Nope all one part:
P/N 6C140-57712
@ ~ $125
__________________
Some days you're being chased by the wolves,
Some days you're running with the pack!
North Idaho Wolfman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
