Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Tractor Operating
Tractor Operating Wondering what that strange lever does, how to safely hill climb or get into 4WD? Discover and share how to get the most out of your tractor.
Reply
Thread Tools Display Modes
Old 04-23-2018   #1
BillK01
2nd Yr. Apprentice
BillK01's Avatar
Default Tie down recs and loacation for BX
Probably getting a 16 foot tandem dual brake Suretrac trailer tomorrow for trailering my BX2360 with FEL and Land Pride RB1560 rear blade as well as assorted hauling etc. This is the one I am thinking about: https://www.sure-trac.com/products.php?trailerId=11
What tie downs do you guys recommend for this and where on the BX do you attach them too for safest hauling? Stopped by tractor supply to look but just got confused with all the options.
Thanks.
BillK01 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-23-2018   #2
Dieselbob
2nd Yr. Apprentice
Dieselbob's Avatar
Equipment: BX 2230, LA211 loader, 60 MMM, 2 wheel spacers, grille guard, gauges, bucket e
Default Re: Tie down recs and loacation for BX
Here are the tie down brackets I made. I used existing bolt holes in the frame and got longer bolts to maintain full thread engagement. These are the recessed rings I have in my trailer floor. On a steel floor, I weld them in and try to place them as close as possible to a crossmember. On a wood floor, I also get them as close as I can to a crossmember, and bolt them through the wood and use a 1/4" steel back-up plate under the floor to spread the load out. In a steel floor, I cut a hole out with a holesaw. On a wood floor, I take a router and cut out a pocket for the ring to sit into.
Click image for larger version
ID:	35566   Click image for larger version
ID:	35567   Click image for larger version
Dieselbob is offline   Reply With Quote
Old 04-23-2018   #3
VIP Service Tech
85Hokie's Avatar
Equipment: BX-25D Filled Rears,Bro Tek Spacers,Piranha Tooth Bar-90'&'92 B7100HST
I too added tie downs to the BX - harbor freight for the D rings.
Tractor supply for the grade 5 bolts.
Name:	2014-06-25 18.01.47.jpg
ID:	35569   Click image for larger version
Name:	2014-06-25 18.02.03.jpg
ID:	35570   Click image for larger version
__________________
"Teaching is the one profession that creates all other professions"
85Hokie is offline   Reply With Quote
Old 04-23-2018   #4
bcp
3rd Yr. Apprentice
Equipment: BX2360
My BX was delivered on a roll-back truck, with front chains hooked and looped on the frame material, and the rear on the frame that holds the hitch plate.
Bruce
bcp is offline   Reply With Quote
Old 04-23-2018   #5
BillK01
2nd Yr. Apprentice
BillK01's Avatar
Thanks guys. What do you do about the FEL and any implements attached to the rear (mine has a Land Pride quick hitch with the RB1560 rear blade). Im assuming those should be secured as well - correct?
Old 04-23-2018   #6
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
Quote:
Correct, a strap or chain for every implement, and FEL.
__________________
Some days you're being chased by the wolves,
Some days you're running with the pack!
North Idaho Wolfman is offline   Reply With Quote
Old 04-24-2018   #7
BillK01
2nd Yr. Apprentice
BillK01's Avatar
Well I picked up the trailer today.
Been a while since I towed a trailer, and never anything as big as this one (just over 19 feet long). It was about an hour and fifteen minute drive home - mostly on the PA turnpike with lots of narrow construction zones. Not ashamed to say it was a white knuckle drive most of the way for me in the pouring rain.
It sure pulled nicely though. Almost like it was not even there.
I did get it backed down my drive on the first shot though!
Old 05-03-2018   #8
DanR
1st Yr. Apprentice
Good job! I went from a "small" 6x12 trailer to my current tandem 7x16 and find it's way easier to back up. I have a 20' truck pulling a 20' overall length trailer and after some practice I can whip that thing around a crowded Walmart parking lot no problem! You'll be a pro in no time. :-)
DanR is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
