Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 04-23-2018   #1
DougMatthews
1st Yr. Apprentice
Default G5200 - Problem with Key Switch?
Just had a problem pop up. Used the tractor quite a bit yesterday, no issues. Sat for a while, user turned the key left to heat the glow plugs. Said it heated for a bit then suddenly stopped.
Checking it out, turning key left (heat) or right (starter) does nothing (no clicks or anything - nothing). Including no red lite above key on the dash.
Battery is couple years old, and good charge. Battery cables replaced last year, connections have conductive grease. New OEM starter last year.
My suspicion is either key switch or power to key switch. Anyone have another idea, or recommendations on how to chase this down?
Thanks!
Doug
DougMatthews is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-23-2018   #2
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
Default Re: G5200 - Problem with Key Switch?
Start probing around with a test light for power, check both cables and check with a light for a ground connection.
__________________
Some days you're being chased by the wolves,
Some days you're running with the pack!
North Idaho Wolfman is offline   Reply With Quote
Old 05-05-2018   #3
DougMatthews
1st Yr. Apprentice
Figured it out. Key switch was only getting 1.8V. Thick-ish red wire coming from starter to dashboard interrupted by a 2-pole connector down by starter. Short loop of green wire on other side of 2-pole had lots of corrosion on connector and wire was failing.
Clipped this out and spliced the red wire straight through. Removed part seemed to serve no purpose - anyone know what this was for? No switches, no fuses. Just a short loop of green wire making the connection across the 2 poles of the connector.
Thanks!
Doug
Old 05-05-2018   #4
Jim L.
3rd Yr. Apprentice
I think that wire is a fusible link. It works like a big fuse.
Jim L. is offline   Reply With Quote
Old 05-05-2018   #5
VIP Service Tech
Thanks!
Doug
UMMMM...The short loop of wire that you removed was the main fuse, called a fuse link, get an new Fuse (40amp) and holder, or a new fuse link, and put it back in.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
