Tractor has 9 hrs. If I put it to full throttle which isn’t often it drifts down below 540 pto run spot. It goes from 3800 to 3200. The throttle lever actually moves. It’ll go back to 3800and stay if I hold it. Can you guys help me out here?
Follow the linkage under the throttle control - there is a "nut" that grips another - you need to tighten this at this friction point.Tractor has 9 hrs. If I put it to full throttle which isn***8217;t often it drifts down below 540 pto run spot. It goes from 3800 to 3200. The throttle lever actually moves. It***8217;ll go back to 3800and stay if I hold it. Can you guys help me out here?
That little engine revs up pretty good !!!Googling images for 'BX1880' instrument cluster shows a PTO range from 3,200-4,000 engine rpm. My guess is that 540 PTO speed is somewhere between 3,200 and 3,500 rpm on the tachometer.
