I recently bought a used L2850 w/ 910 hrs. Tractor runs great but leaks small amounts of multiple fluids (fuel,hydraulic fl, crank case oil) during and just after operating it. I stripped the sheet metal, degreased, and pressure washed it to better assess the leaks for repair. in doing so, I've come across several thinks that have me scratching my head:
1. There are no fluid level check windows as indicated in the owners manual
I received w/ the tractor.
2. I cannot find a serial number for the tractor or the engine per the manual.
3. There is a "V1512-D1" stamped into the engine head but tech data shows
that my L2850 should have a "V1702-DI-A". Do I possible have a 'gray
market' tractor w/ L2850 emblems or did the previous owner replace the
engine with a different but compatable model? What did the V1512-D1
go in initially?
Any info is much appreciated.
-andmel
go in initially?
-andmel
