Trying to get this old tractor running. Smokes like crazy and no power. Pulled the cylinder head and there is a crack in the number 2 cylinder that goes all the way from the injector port through the exhaust valve seat. The tag on the tractor says the engine is a D1301-DA. All of the heads I have found for that engine model have a 4 bolt water inlet, but mine has a 6 bolt. Not sure if the two are interchangeable.
Are there any other engines that will fit in this tractor without too much pain? Not sure if this one has other issues, so not sure it is worth just replacing the head if I can even find one that fits.
