I purchased a used 2006 B2630 a couple of months ago, and being new to diesel engines, I didn't realize the problems associated with running out of fuel. Thanks to this website and their Youtube video, I learned how to bleed air from the fuel lines and got things running again. After a few weeks of running fine, I let it set for about a week. When I tried to start it again, it ran a few seconds then died, just like it did when I ran out of fuel. I bled it again, it ran a few seconds then died. Eventually, I decided to replace the fuel filter. There was some gunk on the inlet side of of the housing where fuel enters the bowl. Clean it, installed new filter and o-rings, bled the lines, and tried to start it. Same results, it ran a few seconds then died.
When it runs for a few seconds, before it died, I observed the fuel in the filter bowl being sucked low. After the engine shuts off, the fuel level in the bowl very slowly starts to rise.
Thinking it might be related to the gunk I removed from the inlet side of the fuel filter, I checked fuel supply to the filter and if flows freely. After replacing the bowl I checked the outlet side by removing the fuel line. Fuel does not flow out of the filter when this line is removed. Is this normal?
I'm not sure if I should keep troubleshooting up the fuel supply path, if the problem is related to the filter, or whether I'm just not bleeding the system adequately, or if it's something altogether different.
Any help would be appreciated. Thanks!
