Dog Trot Acres
ZEN-NOH ZL1501DT with a 1846QT BUSH HOG frontend loader, 4 ft BUSH HOG
Recently bought a ZEN NOH ZL1501DT tractor from a guy. It has a Bushhog brand frontend loader model 1846 QT mounted on it. I got a 4 foot bushog, 5 foot finish mower, 4 foot box blade, and a ripper blade. The tractor has 3047 hours on it. It runs good. It is not pretty but I didn't buy it for looks. We just bought 3 acres to build a HOMESTEAD on and that is what we plan to use it for. I am planning on doing a oil and filter change, fuel filter change, air filter change. Going to grease all of the grease fittings and give it a good pressure washing. I plan on using engine degreaser and then pressure washing it too. I have all ready installed a new battery, sharpened the Bushhog blades, installed a new muffler with flapper valve cover. It has a set of external aftermarket gauges for voltage, oil pressure and temperature. The oil pressure gauge had a leaking line. I fixed that. It has good pressure. I plan on rewiring the whole tractor and moving these gauges into the stock dash bezel. I also plan on adding all led work lights, replacing the stock headlights with led, a small led light bar, plus the red and orange safety lights on the back fenders.
Other then the maintenance I listed is there anything else I should do/check on? Any help with this would be greatly appreciated. I will post so pics as soon as I get enough posts.
