coachgeo
My apologies; tried searching first but all the terms for searching this topic match with a million of other topics too.
Anyway..... My oil leaks a little out the hour meter/tach gear on the engine cause I have it removed temporarily and a blanking plate to cap the area is apparently not sealing well. No big deal... I'll just top of the engine lube.
Went to check the oil level and saw that I got PLENTY of oil. Makes me leary that maybe my oil is getting contaminated by Hydro or diesel. My search was to read up on best way to determine which it might be. Sure if diesel contamination is real bad you could smell it in the oil maybe.
Any other suggestions?
Or could it be what is leaking from the blocking plate at the hour/tach area is not engine lube oil but fuel or hydraulic oil? does not smell like fuel though
