B2601 mower deck park?
slauso
B2601,LA434 loader
Apr 7, 2018
17
canada
I will be taking delivery of my new B2601 next week. One thing the salesman told me is the mower deck and 3 point lower at the same time. On my BX2230 you could put the deck at the TOP position and it would stay up while the 3 point lowered. Does anyone know if the salesman is correct. I hoping it isnt.
Thanks
jpf
120
12
butler, ga USA
you will have an adjustment knob, when you raise the mower deck up all the way and adjust that knob it will hold the deck up even if you lower the tph.
slauso
B2601,LA434 loader
Apr 7, 2018
17
canada
My BX2230 had that knob. I was looking at the B2601 today and there was no such knob. Only the 3pt speed adjust knob. The new tractor has the the position control valve with a graduated scale by the 3pt lever. That is how you set your cutting height I was told.
jgregory2010
B2301
Mar 14, 2018
26
Granville, OH
On my B2301 there is an adjustment knob but I have also noticed that you only need to lower the arms slightly to get the mower all the way down. The position control lever doesn't need to be completely lowered.
slauso
B2601,LA434 loader
Apr 7, 2018
17
canada
The cutting deck is not installed yet so im wondering if the adjustment dial comes with the deck itself.....thanks JPF...i checked the pics in the brochure and it does show a height adjust dial.
jpf
120
12
butler, ga USA
well I never thought about that, without a mower deck there wouldn't be any need for a hight adjusting knob, so maybe it is installed along with the deck itself?
my mower deck was installed before I seen the tractor so I don't know?
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
323
102
St. Louis, mo.
My b2601 with the 60” deck has the adjusting knob. When I turn the knob to the “top” position it locks the deck and I can raise or lower the 3pt independent of the mower deck
Jetech
42
Iowa
My 2601 operates the same way. Raise the deck full up and turn the knob to "top". I greased the mechanism to make the knob turn easy.
groomerbuck
137
Palmerton, Pennsylvania,
All b2601 are a suspended deck so the mower WILL have its own knob to select cutting heights. Your salesman may have confused the 2601 with the 2650. The 2650 are ground following decks which work off the 3point hitch.
slauso
B2601,LA434 loader
Apr 7, 2018
17
canada
I think I was panicking to soon. Thanks everyone......the salesman should have known this. I think I will tell him that he should be a little more knowledgeable about what he sells.
