Rtv 900
Tony1966
Rtv900
May 25, 2018
Santa Cruz ca
Hi new member here i’m working on a RTV 900 with a low power problem. It goes fine on level ground but once you try to go up hill slows way down engine sounds fine but it feels like you need to get out and push. I check the air filter and fuel filter both are clean. I normaly work on larger tractors so i have to admit i need help on this one
lugbolt
ZG127S-54
Oct 15, 2015
4,842
1,595
Mid, South, USA
Well, the post doesn't give a lot to go on. Does the engine RPM drop significantly when the power drops off, as if the engine is weak? Or does the engine speed stay more or less the same and the travel speed just drop off, as if it had a "slipping clutch"?
kuboman
725
Is this a new machine to you? From what you describe it sounds like a normal RTV900. They are not a hot rod. But, we need more info.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Welcome to the OTT forum Tony. You came to the right place to get answers.
