T Tx Jim Well-known member Lifetime Member Equipment M7040 HDC-1,JD 4255,Ford 6700 Apr 30, 2013 1,179 117 63 Coyote Flats,Texas Jan 25, 2015 #1 Does a B2920 with a FEL have a 3 pt hitch relief valve in rockshaft housing? Thanks,Jim
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,676 5,100 113 Sandpoint, ID Jan 25, 2015 #2 It does not appear so, looks like it's all done in the loader control. The three point just has a simple valve. Problem?
T Tx Jim Well-known member Lifetime Member Equipment M7040 HDC-1,JD 4255,Ford 6700 Apr 30, 2013 1,179 117 63 Coyote Flats,Texas Jan 26, 2015 #3 No not really.That question was asked on another forum and I couldn't locate RV in parts schematics. Thanks for your reply,Jim
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,676 5,100 113 Sandpoint, ID Jan 26, 2015 #4 Yea the only relief valve I could find is in the loader valve and by design ( mounted to the side of the three point ) and routing of the lines ( relief valve dumps to tank ), it looks like it's doing all the regulation in the system.
