Hello: I am new to this forum.
I own a M95S with a LA1301 Loader.
I use it mostly in hay production. Back in December, I was run off the edge of the road and broke two chains and the tractor come off the trailer. the loader saved the tractor; however the loader was mangled. The local Kubota Dealer installed a new loader on the tractor. The loader appeared to work properly.
Recently, I have had to start the hay season. I roll 6'diax5'wide rolls.They routinely weigh about a ton. The first time I used the loader for this application the loader started giving me trouble.
The up and down or raise and lower works perfectly!
The tilt will tilt up - with no issues.
The tilt down - will not lower properly. If I take the engine rpm to idle and crack the valve slightly, I can get the tilt to lower. If the engine rpm is above idle - forget it. you can see the tilt start to lower and then a bump in the up direction and no more movement.
I have switched the loader lines at the quick connects and the tilt will work perfect and the problem goes to the raise and lower. Except it will only go up. with applying side to side stick movement, the loader only raises. I had to shut the engine down and operate the stick to get the loader back down.
This test tells me that the problem is not in the cylinders on the loader?
The local Kubota dealer is telling me he is at least a month behind, hay season is kicking my butt. I am using the tractor to load out, but it is a real slow process.
Here is a pic of me coming out of the field with a load.
