Just an introduction
2,166
Recently bought a 1979 B7100 and wanted to get on with some folks who can help me learn about my tractor. Looking forward to meeting you.
Cave Road
congrats!
You'll find a lot of wealth of knowledge on the model here - it might be the top model (maybe behind the BX2x series)
It is a bullet proof machine - for a compact tractor it will pull it's weight around like no other!
It does have a few potential bug-a-boos when you do not know what to look for .......
it has no water pump, so you have to keep the cooling system clean as a whistle
it does not have an alternator .....it has a dyno - and it can be a PITA to replace or repair, but it really is not that bad....once you BTDT!
What type tranny you have ? Geared? HST? 4wd or 2?
What questions do you have - and no, there are never stupid questions.....especially if you do NOT know the answer! :D:)
Glad to have you here !
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Welcome to the OTT forum Cave Road. We are glad that you joined with us here.
Congrats on the new tractor. We all like pictures. Remember, no pics then it didn't happen. :D
OBKubota
2014Gr2120,Gr2728Snowblower,Gck5GrassCatcher,agri-FabSpreader
Oct 21, 2014
205
Ontario
That might be his pet rock!
procraftmike
1977 B7100DT w/B219 FEL
Jan 27, 2016
277
10
Neenah, WI
Welcome aboard!
I have a 1977, B7100, 4wd, gear tractor. It is a beast for it's size. You will be very impressed with it. It is the little tractor that thinks it can....and most of the time it can.
Cave Road
22
Campbellsville, KY, USA
Hey, thanks for the welcome in comments. My 7100 is a geared 4wd. I have already been pleased with it's "want to". The tractor came with a Woods 48" finish mower and the three-way hydraulic front blade.
I can see the need for weights at least on the rears. I think weights on the fronts may make steering too difficult. The future almost definitely holds a box blade and a 4' bush hog for the tractor. I'll be getting a "heavy hitch" or similar soon to handle a trailer and to get a draw bar.
I obviously need to check the cooling system if that is a potential problem.
First question, why do I have a four speed PTO?
Cave Road
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Welcome to the neighborhood. We need proof of life POST SOME PICTURES please ;) :p ;)
lil foot you are such a show off,,lol :D
Are you just now noticing?? :eek: :eek: :eek:
Well I guess when you got you gotta flaunt it :D :D :D
2,234
Well, everybody likes pics, and I've only posted those 3 or 4 times.:D
Lil Foot, has his tractor chained to that rock so nobody steals his tractor!
Won't work, it will just drive away with it!
I beg your pardon? That's a new one on me.
Cave Road
22
A four speed PTO. My label is worn out so I'm not certain of which speed is which. When i went on KUBOTA manuals the description is of speeds 540, 750, 1000 (I think), and 2000 (I think). The PO told me to pull the handle back one notch for 540 for a bush hog, etc. Push forward one notch for 750 for the Woods mower. The other two are a complete mystery. I know I would have to move the guard at my left foot to get the other two speeds available. Not that I want them, just wondering why they are available.
1,000
I think the other speeds are for other countries where designs are different
The number 1 PTO is 540 RPM ON MY L185 tractor
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
304
98
Nicollet, mn
540 is the old standard on ag equipment
750 is unknown to me
1000 is common on newer ag equipment
2000 is a garden tractor thing not seen any more
5,094
You have 3 speeds on the rear PTO not 4.
You should not use the 750 or 1000.
unless the woods mower is an odd model the input should be 540.
540 Is the universal standard, that was adopted around the time the B7100 where out.
The other speeds were based on older equipment that was still in use and available at the time the b7100 came out.
Tooljunkie
May 13, 2014
4,150
27
It was my understanding the higher rpms were used for things like water pumps and generators. Mowers were intended to run at 540. Yet mine cuts better at slightly higher speed. 600 maybe. Guessing at rpms isnt easy,2/3 throttle would be my guess for a starting point.
