hey guys
I removed the injector pump due to a leak, which it was running fine at the time. put all new factory orings in the pump, fully disassembled it.reinstalled it and mounted it back on machine. bled system ,was getting a spirt of fuel with the lines off. mounted lines and started up, engine now is running away. it looks like it is getting extra fuel due to the amount of smoke being produced. I did also install a new intake gasket which has to be removed to remove the pump. I'm wondering if I could of installed the pump element that runs up and don in the housing backwards. does anybody have a assembly guid for this? thanks in advance
