Hi everyone,
I have a B1750HST 1996 (I believe). I'll list my symptoms:
1. The clutch does not disengage the drive wheels or the PTO.
2. The clutch pedal engages the left brake pedal.
Things I've checked/looked at:
1. Pulled the pin connecting the left brake pedal to the shaft
->Left wheel still braked by clutch pedal. Left brake pedal loose!
2. Verified clutch linkage is connected and moving. I noticed the clutch pedal has one short linkage which I assume runs to the clutch, and a second linkage running back to the rear of the tractor. Both appear to moving freely.
3. Drive shaft under the filter housing cover spins at all times (clutch pressed or not) when tractor is running.
The tractor runs and starts fine with the PTO engaged or disengaged.
Any ideas? Frozen clutch? I can snap some pictures if it would help.
Thanks!
Thanks!
