Thanks Sidecar, The 5040 is primarily a cable between levers but you may be correct on the low pressure, when put in forward it does try to move very slowly. The filters and hydraulic fluid were changed less than 100 hours ago and the level is correct, I am using the Kubota Super UDT fluid. I hate having to haul it in to the dealer but I guess that would be better than splitting.
The valve is supposed to modulate the load on the pack relative to 'sensed' load on the tractor. How it does that, not sure but with mine, when I engage the shuttle lever with no load on the tractor, engagement is gentle. When I have say my hay mower on the back, engagement is much more abrupt.
You can check the pack pressure via a liquid filled gauge and fitting, there is an access port on the side of the valve body. The correct engagement pressure is in the WSM. Forward and reverse is mechanical in the transmission via shift forks operated in conjunction with the lock up pack pressure.
For my end use, the hydraulic shuttle is far superior to any dry clutch. When round bailing, I'm constantly starting and stopping and pto rated speed. A dry clutch would never hold up under those circumstances.
I'd actually prefer a CVT but that won't happen for me so the Hydraulic Shuttle is the next best alternative.
I don't use Kubota fluid at all. I use Chevron Synthetic All Weather THC. in the case, 80-90 GL4-5 in the front axle and Rotella 5-40 T6 in the crankcase, but Kubota filters always.
