Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 12-29-2009   #1
Bellinghamster
1st Yr. Apprentice
Equipment: B7100 with FEL
Default Trying to find a cylinder head or engine for my B7100
I'm not having much luck finding an (affordable) cylinder head my B7100. My (new to me) tractor came with a cracked head. I thought it'd be a piece of cake to find a head or a complete motor since B650/750/850/950 motors were used for so many applications (Onan generators, mobile truck refrigerators, tractors, welders, light towers, Bobcats, forklifts, etc.), but since the only thing that ever seems to go wrong with them is cracked heads, all the used heads seem to have been snatched up.
Does anyone out there have a good cylinder head they want to part with, or a complete running D750, D850 or D950 (with a spline PTO on the front pulley)? Anyone?
Much appreciated!
-Pete
Bellinghamster is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-10-2010   #2
Weimsnks
New Member
Default Re: Trying to find a cylinder head or engine for my B7100
Pete,
Sorry so late,
I had the same thing with my B7200. I found this shop.
http://www.cylinderheadrepair.com/default.htm
It is very common with these engines. The waterpump goes out, you run dry on water and the rest you know.
It ran me $450 which isn't bad as the bare casting is $900.
I went ahead and completely went through the head with ALL new parts and was at $800 for the total repair which included a rebuilt waterpump, head gasket and rebuilt injectors.
My Dad who has done cylinder head work for as long as I have known was very pleased with the quality of work and the tractor ran for 3 yrs when I sold it.
Jeff
Weimsnks is offline   Reply With Quote
Old 02-10-2010   #3
Eric McCarthy
VIP Service Tech
Eric McCarthy's Avatar
Equipment: Kubota B6100E
Have you checked out West Kentucky Tractor? They have a junkyard full of all types of tractors. Almost every make and model.
http://www.wkytp.com
Eric McCarthy is offline   Reply With Quote
Old 02-10-2010   #4
Bellinghamster
1st Yr. Apprentice
Thanks all. I ended up finding a D950 that I could check out in person. It had good compression and oil pressure and a water pump, but it was from an Onan marine generator.
It took some creative work to get it to fit (different timing gear cover - had to be trimmed to fit the front frame, oil filter on the other side of the engine that interfered with the front frame - solved by adding a remote oil filter, no PTO out the front - fabricated PTO shaft that bolts onto the front pulley, different cooling hose size and locations - had to make a crazy pipe assembly to use the use the old radiator, different flywheel - swapped the one from the D750.. oh, and all the studs in the head had to be transferred due to different lengths... and swap oil pans and sump pickups). I'm REALLY good at taking off/putting on the head and oil pans on these motors now!
Initially after figuring out all the differences and realizing that my original plan to swap the timing gear cover from my D750 onto the D950 wasn't going to work (950 has a passage into the block for the water pump that the 750 cover wouldn't, well, cover), I had tried swapping the D950 head onto my D750. I had put in new rings, but it really needed new liners as well. The valves in the D950 head are larger and it was too finicky for comfort to get the head lined up so they wouldn't rub on the cylinder walls... It was a comedy of "this should work... uh, nope. try this.. nope.. try that... nope... now what? Can I return the D950.. not really... now what? What if I... yup... this should work. I just need to make a... now what?. In the end I managed to make it work without any modifications to the tractor frame, so I can always return to stock if I trip over a good running D750. For now it's all put together and running and I'm happy. The only thing that's a little funky is the injection pump governor for a generator is set up for much tighter speed regulation - most diesel governors are a bit "softer". When I let out the clutch or load the motor it doesn't slow down even the slightest bit. Changing throttle position results in instantaneous response. This makes it a bit jerky. I may try adjusting it or swapping the governor guts out of my D750... someday.
So.. I've got $150 worth of new rings that I can't return because I installed 'em in the D750 before deciding not to go that route. (It isn't worth the ~$400 to replace the cylinder liners in since it also needs a new head). I've also got a D750 head gasket that was torqued down but not run, and a timing gear gasket for a D750 that won't fit my D950. Anyone interested in a good deal on some almost-new D750 parts?
Old 02-11-2010   #5
Greg
2nd Yr. Apprentice
Equipment: B7100 HST-D 4x4 with FEL, PTO and 3 pt hitch
This might be a little late, but there is one on ebay right now
http://cgi.ebay.com/New-KUBOTA-TRACT...item2eab0a4e06
Greg is offline   Reply With Quote
Old 02-11-2010   #6
Bellinghamster
1st Yr. Apprentice
Now that was just cruel
Reply
Tags
cylinder head, engine, head, wanted
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
