Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Implements & Attachments
Implements & Attachments Find everything related to operating, servicing and maintaining that loader, mower, blade, snow blower, tiller, hitch or scraper, right here.
Reply
Thread Tools Display Modes
Old 11-01-2009   #1
BIRD
1st Yr. Apprentice
Default belly mower
will a rc72-29a mower deck fit b6200?
if not does anybody know what model i should be looking for
BIRD is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-07-2009   #2
P.Holm
1st Yr. Apprentice
P.Holm's Avatar
Equipment: L2250 4WD,FEL,60"belly mower,60" JD bush hog,60" JD box blade-Kubota T1400
Default Re: belly mower
RC60-72 or RC48-62 are the largest belly mowers I see listed for a b6200
Hope it helps!
Paul
P.Holm is offline   Reply With Quote
Old 11-09-2009   #3
BIRD
1st Yr. Apprentice
paul thanks for the reply. could you tell me where you seen that listed thanks brent
Old 11-09-2009   #4
P.Holm
1st Yr. Apprentice
P.Holm's Avatar
Kubotas lookup utility
http://www.kubota.com/h/PartsCat/PartsCatDetail.asp
Good luck with the deck search
Paul
Old 11-19-2009   #5
dusty-t
4th Yr. Apprentice
dusty-t's Avatar
Hi Bird. I got some pics of that B7200. I hope they help a bit. I could not find a model number. It looks like a 48 in deck. Dusty
Click image for larger version
Name:	DSC00603 [1024x768].jpg
ID:	808   Click image for larger version
Name:	DSC00604 [1024x768].jpg
ID:	809   Click image for larger version
Name:	DSC00605 [1024x768].jpg
ID:	810   Click image for larger version
Name:	DSC00606 [1024x768].jpg
ID:	811   Click image for larger version
Name:	DSC00607 [1024x768].jpg
dusty-t is offline   Reply With Quote
Old 11-20-2009   #6
BIRD
1st Yr. Apprentice
thanks for the pics dusty once i find a deck i may need a few more
Old 11-21-2009   #7
toyz4roy
New Member
Equipment: b7500
I have an rc 60 and the mounts from my b6200 that I would sell if your interested. I had a 48" deck as well but when I traded the tractor I kept the 60" . It has all the mounts and lift arms that guards are in rough shape. It will need a pto shaft and one idler wheel as those were missing when I bought it. The blades are new and so is the belt.
toyz4roy is offline   Reply With Quote
Old 11-21-2009   #8
dusty-t
4th Yr. Apprentice
dusty-t's Avatar
Hi Bird , The mounts for the deck may be different on a hydrostat tractor than a gear drive because of the difference in bellhousings. Just so you know....Dusty.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
