cracked rim - no replacement available
Redpine
B21 TLB, b9200d, bf350
Apr 24, 2014
32
Seattle
B21 rear wheel rim has a crack that circles the bolts. No replacement available.
Ordered and paid for one at Kubota dealer and a week later was told not available. (unless we buy one with a tire that does not match and we do not need) Coleman equipment also told me it is not available.
Any suggestions?
The other rear rim was replaced before we acquired the tractor with the new version of the rim.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
You might could be able to have it repaired. It's not a highway vehicle, so it's not 'as crucial' (emphasis on as crucial) of a fix.
I see the crack in the pic, you sure it's steel and not just the paint? Not to question your judgement, but I don't know how inclined you are.
SidecarFlip
Banned
546
Any competent weld shop can gouge the crack out and weld and grind it. After a rattle can paint job, only you will know.
5,107
Look on Ebay, You'll need to know the size and width of the rim, Bolt spacing, and center size hole.
Or find a local rim repair/ manufacturer, they should be able to make you the rim or put a new center in yours.
4,059
I'd make a 'reinforcement' ring from 1/8" plate, about 2" wide with appropriate holes and have it welded onto the rim. There's more than enough threads to remount the rim. I've done this with bigger tractors with loaders, on the front rims . Too much stress for a regular rim. I'm surprised to see it on the rear though maybe it's been abused in the past or bad steel ?
Jay
Yooper
3901 LA525
May 31, 2015
1,460
432
NE Wisconsin
Jay
+1 on this if you can not source a rim. I would recommend going with 1/4 steel or a little thicker and around 12 inches in diameter. Also, do not weld continuously around the rim. Use stitch welds to allow for stress relief. Cover it with something after welding to slow down the cooling to prevent thermal shock.
3,032
YES! Use STITCH WELDS!
shootem604
Apr 23, 2018
875
British Columbia
My L225 had those hard to find front wheels, so the previous owner had just cut, welded, and drilled some plates, good for another 35 years. Find someone who know what they are doing and you should be good to go.
motionclone
May 4, 2018
1,398
992
Maine
Surprised nobody has mentioned it but the tire should be dismounted before welding on rim. Could be dangerous situation if tire is left on rim.
4,389
I don't see how stitch welding the donut plate with the tire on the rim would cause any problem when taking your time. What do you think will happen?
5,128
933
It is all about this irreversible fast tire decomposition called pyrolysis.
You do not know you have started it and then you cannot stop it. This degradation process can also be started in ways other than welding such as:
overheated brakes
equipment contact with high voltage power lines
tire or equipment fires
lightning strike
driving long distances with underinflated tires
In most North American jurisdictions it is illegal to weld a rim with the tire on it because people have been killed.
https://www.youtube.com/watch?v=HiLeji8bLOk
Pyrolysis is a thermochemical decomposition of organic material which can occur at elevated temperatures in the absence of oxygen. This decomposition process only requires the presence of rubber and heat. When heat is applied to the tire or to tire components, hydrocarbon vapors are released inside the tire. As the vapors are released, the air pressure and temperature within the tire increase dramatically. These vapors are highly flammable. If the flammable vapor inside the tire makes contact with oxygen at a temperature in excess of 400 degrees Celsius, auto-ignition can occur, resulting in an explosion.
Once the decomposition process begins, it is irreversible. There is no visual indication that the decomposition process is taking place. Depending on the particular circumstances, an explosion may occur immediately, within minutes or several hours after the exposure to the heat source. In many instances, an explosion can cause the tire and/or wheel components to be thrown great distances, resulting in severe worker injuries and/or fatalities as well as significant property damage.
shootem604
Apr 23, 2018
875
British Columbia
overheated brakes
lightning strike
I learned something new today.
L35
Jun 13, 2010
421
244
CT
Can you just pull the valve stem to prevent buildup?
4,389
I thought we were discussing stitch welding a disc to the wheel for additional support.
Have you ever taken an old automobile body panel and cut it just to weld back together? Much amperage applied too long and you have a mess. However, you weld a spot, then let it cool, or even use a damp cloth to cool and go on.
Welding a tractor wheel with much higher amperage, but going slow and letting it cool....there is no way you are going to get it 400 deg at the tire. Or maybe the tires that were on the rims I welded on were prehistoric rubber and not affected, but they were 16.9x38 tires.
SidecarFlip
Banned
546
Glossed over it. Don't apply anyway. Not tossing the rim and tire in a bonfire, just doing some welding on the spider.
People today take something simple and complicate it. For what reason, I have no idea except maybe to inflate their ego's.
Duh.
SidecarFlip
Banned
546
An imaginary issue. If in doubt take the tire valve core out. Much simpler than pulling valve stem.
Duh again.
motionclone
May 4, 2018
1,398
992
Maine
lol at sidecarflip
