Kubota L Series Clutch Repair Pricing
Wondering how much that clutch job might be for your L series Kubota?
OrangeTractorTalks reader Brian recently requested a quote for what we call a clutch overhaul kit for his L2350. This estimate is for a single disc dry clutch, and although for the L2350, other similar models like L2050, L2250, L2550, L2650 or L3250 would have similar pricing for these clutch components. If you are thinking of tackling this job as a DIY’er, plan on setting aside 8-10 hours – a good long weekend job.
Kubota L2350 Clutch Repair Pricing
| Part | Notes | Price |
| Clutch Disc | replace as a set with pressure plate | $97.40 |
| Pressure Plate | replace as a set with disc | $132.00 |
| Release Bearing | $32.39 | |
| Release Hub | $31.67 | |
| Hub Release Return Spring | $2.38 | |
| Clutch Release Fork | often worn and causes binding | $28.50 |
| Total | $324.34 |
*prices in USD
Related Articles
10 Tips to Save Wear on your Kubota’s Clutch
Getting to Know your Kubota’s Clutch
Forum: Service, Repair & Maintenance
kenny obier Said,
March 2, 2009 @ 6:54 pm
How much for a wet clutch assembly for a L3650 Kubota, part #35080-1420-0? Are there any aftermarket brands. Can these be resurfaced? Any help would be appreciated. 214-763-8554. Kenny
Vic Said,
March 2, 2009 @ 8:01 pm
Kenny, they are stupid for pricing if I remember, something in the $1400-1500USD price range if I remember!
Shop that resurfacing question around to a few local clutch rebuilders, you may be surprised at what you find! I can sell you a new one, but it’s gonna hurt!
William Stover Said,
July 6, 2009 @ 9:26 am
I would like to know if anyone has had any trouble loosing a freeze plug in the oil jacket in the left front corner on the engine of a Kubota L3010 and having the rod and #3 piston broken and put a hole in the block and smashed the crank beyond being able to be turned or repaired. This engine had less then 1300 hours on it even thou it is only 9 years old.
