Gray Market Kubota Fuel Filter Part Numbers
This is the last table of this kind that cross-references air, fuel or oil filters from several manufactuerers. With this chart, if the original Kubota part is not available, or is priced more than you would like to spend, you can find the comparable filter from NAPA, Baldwin, Wix or Fram.
Other Charts of Interest
Air Filter Part Numbers
Oil Filter Part Numbers
To use this Chart
Simply locate the model number of your gray market Kubota (or its engine) in the left-most columns to then see comparable fuel filters.
| Model | Engine | Kubota | NAPA | Baldwin | Wix | Fram |
| B1200 | D750 | 15231-43560 | 3389 | PF872 | 33389 | C6921 |
| B1400 | D850 | 15231-43560 | 3389 | PF872 | 33389 | C6921 |
| B1600 | D950 | 15231-43560 | 3389 | PF872 | 33389 | C6921 |
| B1902 | D1102 | 70000-43081 | 3390 | BF7683 | 33390 | P7514 |
| B5000 | Z500 | 15231-43560 | 3389 | PF872 | 33389 | C6921 |
| B5001 | Z500 | 15231-43560 | 3389 | PF872 | 33389 | C6921 |
| B6000 | ZL600 | 15231-43560 | 3389 | BF7683 | 33390 | P7514 |
| B6001 | D650 | 15231-43560 | 3389 | PF872 | 33389 | C6921 |
| B7000 | Z650 | 15231-43560 | 3389 | PF872 | 33389 | C6921 |
| B7001 | D750 | 15231-43560 | 3389 | PF872 | 33389 | C6921 |
| L200 | Z1100 | 70000-14630 | 3511 | PF906 | 33511 | P7514 |
| L240 | Z1300 | 70000-14630 | 3511 | PF906 | 33511 | P7514 |
| L260 | Z1300A | 70000-14630 | 3511 | PF906 | 33511 | P7514 |
| L1500 | Z750 | 15221-43170 | 3390 | BF7683 | 33389 | P7514 |
| L1501 | Z751 | 15221-43170 | 3390 | BF7683 | 33389 | P7514 |
| L1511 | Z751 | 15221-43170 | 3390 | BF7683 | 33389 | P7514 |
| L1801 | Z851 | 15221-43170 | 3390 | BF7683 | 33389 | P7514 |
| L2000 | D1100 | 15221-43170 | 3390 | BF940 | 33390 | P7514 |
| L1802 | D1102 | 70000-43081 | 3390 | BF940 | 33390 | P7514 |
| L2002 | D1302 | 70000-43081 | 3390 | BF940 | 33390 | P7514 |
| L2402 | D1402 | 70000-43081 | 3390 | BF940 | 33390 | P7514 |
| L2602 | V1502 | 70000-43081 | 3390 | BF940 | 33390 | P7514 |
| L2802 | V1502 | 70000-43081 | 3390 | BF940 | 33390 | P7514 |
| L3202 | V1502 | 70000-43081 | 3390 | BF940 | 33390 | P7514 |
| L1-18 | D1402 | 70000-43081 | 3390 | BF940 | 33390 | P7514 |
| L1-20 | D1402 | 70000-43081 | 3390 | BF940 | 33390 | P7514 |
| L2201 | D1101 | 15221-43170 | 3390 | BF940 | 33390 | P7514 |
| L2600 | V1500 | 15221-43170 | 3390 | BF940 | 33390 | P7514 |
| L2601 | D1301 | 15221-43170 | 3390 | BF940 | 33390 | P7514 |
| L3001 | V1501 | 15221-43170 | 3390 | BF940 | 33390 | P7514 |
| L3602 | V1902 | 15221-43160 | 3507 | PF717 | 33507 | |
| L1-22 | D1462 | 15521-43160 | 3507 | PF717 | 33507 |
Related Articles
Gray Market Kubota Air Filter Part Numbers
How to Bleed Kubota Fuel Injector Lines
Kubota Servicing 101: Part 2 – Fuel Filter
Forum: Gray Market & Zennoh
